Title | Size | Downloads |
H3C S9500 Series Routing Switches Operation Manual(Release1648 V1.24)-System Volume.pdf | 1.73 MB |
- H3C S9500 Operation Manual-Release1648[v1.24]-08 System Volume
- 00-1Cover
- 01-Command Line Interface Configuration
- 02-Login and User Interface Configuration
- 03-FTP and TFTP Configuration
- 04-HA Configuration
- 05-NQA Configuration
- 06-NetStream Configuration
- 07-NTP Configuration
- 08-RMON Configuration
- 09-SNMP Configuration
- 10-Packet Statistics Accounting Configuration
- 11-Device Management Configuration
- 12-Configuration File Management Configuration
- 13-File System Management Configuration
- 14-Cluster Management Configuration
- 15-System Maintenance and Debugging Configuration
- 16-Information Center Configuration
- 17-PoE Configuration
- 18-Clock Module Configuration
- 19-ACSEI Server Configuration
- 20-OAP Module Configuration
- H3C S9500 Series Routing Switches SecBlade FW VPN Cards Operation Manual(V1.03)
- H3C S9500 Trap Message(V1.00release 1250 or later versions)
- H3C S9500 SLM(V1.00release 1250 or later versions)
- H3C S9500 Series Routing Switches Compliance and Safety Manual(V1.04)
- H3C S9500 Series Routing Switches Installation Manual-(V1.01)
- H3C PoE DIMM Module Installation Guide(V1.02)
Manual Version
T2-08165E-20081225-C-1.24
Product Version
S9500-CMW310-R1648
Organization
The System Volume is organized as follows:
Features (operation manual) | Description |
Command Line Interface | The S9500 series provide a series of configuration commands and command line interfaces for configuring and managing the switch. The volume describes: l Command line interface l Command line view l Features and functions of command line |
Login and User Interface | The volume describes: l Setting up configuration environment through the console port l Setting up configuration environment through telnet l Setting up configuration environment through modem dial-up |
FTP and TFTP | FTP and TFTP are methods for transmitting files on the Internet and IP networks. The volume describes: l FTP overview l FTP configuration l TFTP overview l TFTP configuration |
HA | High Availability (HA) is to achieve a high availability of the system. The volume describes: l HA overview l HA configuration |
NQA | A network quality analyzer (NQA), which is an enhancement of the ping function, is used to test the performance of various protocols operating in a network. The volume describes: l NQA overview l NQA configuration |
NetStream | NetStream provides the packet statistics function. It can classify the stream information according to the destination IP address, destination port number, source IP address, source port number, protocol number and ToS of the packet, and performs independent statistics for different stream information. The volume describes: l Netstream overview l Netstream configuration |
NTP | Network Time Protocol (NTP) is the TCP/IP that advertises the accurate time throughout the network. The volume describes: l NTP overview l NTP configuration |
RMON | Remote Monitoring (RMON) is a type of Internet Engineering Task Force (IETF)-defined MIB. RMON helps the SNMP monitor the remote network device more actively and effectively, which provides a highly efficient means for the monitoring of the subnet operations. The volume describes: l RMON overview l RMON configuration |
SNMP | SNMP has been put into use and widely accepted as an industry standard in practice. It is used for ensuring the transmission of the management information between any two nodes. The volume describes: l SNMP overview l SNMP configuration l Trap configuration |
Packet Statistics Accounting | The volume describes: |
Device Management | With the device management function, the switch can display the current running state and event debugging information about the slots, thereby implementing the maintenance and management of the state and communication of the physical devices. The volume describes: l Device management overview l How to manage devices (such as reboot the device, upgrade Boot ROM and specify Bootstrap programs for the device) |
Configuration File Management | The management module of configuration file provides a user-friendly operation interface. It saves the configuration of the switch in the text format of command line to record the whole configuration process. The volume describes: |
File System Management | The switch provides a file system module for user’s efficient management on the storage devices such as Flash memory. The file system offers file access and directory management, mainly including creating the file system, creating, deleting, modifying and renaming a file or a directory and opening a file. The volume describes: l Introduction to file system management l File system management configuration |
Cluster Management | Cluster management enables management devices to administrate switches in a centralized way and allows switch cascading. The volume describes: l HGMP Server configuration l HGMP V1 configuration |
System Maintenance and Debugging | For the majority of protocols and features supported, the system provides corresponding debugging information to help users diagnose errors. The volume describes: |
Information Center | The information center is an indispensable part of the switch to classify and manage system information. The volume describes: l Introduction to information center l Information center configuration |
PoE | Equipped with external power supply and PoE-capable cards, the switches can provide power for remote powered devices (PDs). The volume describes: l PoE overview l PoE configuration l PoE PSU supervision configuration |
Clock Module | The clock module is responsible for providing high-precision and high-reliability synchronous 38.88 MHz SDH clock signals for all LPUs. The clock module selects an input clock source automatically, performs software phase-lock function, and monitors the board status in real time. The volume describes: l Introduction to clock module l Clock module configuration |
ACSEI Server | As a private protocol, ACSEI provides a method for exchanging information between ACFP clients and ACFP server. The volume describes: l ACSEI overview l ACSEI Server configuration |
OAP Module | Open Application Platform (OAP) is developed based on Open Application Architecture (OAA). It can be an independent network device, or a board used as an extended part of a device. We call this kind of board as an OAP module. The volume describes: l OAP overview l Logging In to the operating system of an OAP module |
